Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/pnAPI.php on line 670
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/pnAPI.php on line 573
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/Xanthia/pnclasses/Xanthia.php on line 562
Thema: In diesem Thema sind folgende Beiträge:
Deprecated: Non-static method ADOConnection::UnixTimeStamp() should not be called statically, assuming $this from incompatible context in /www/htdocs/w0058ef5/ausfahrten/includes/classes/adodb/adodb.inc.php on line 2813
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 971
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 972
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 973
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 974
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/includes/pnLang.php on line 991
Deprecated: Assigning the return value of new by reference is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/pn_bbcode/pnuserapi.php on line 435
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/classes/safehtml/safehtml.php on line 366
Deprecated: preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead in /www/htdocs/w0058ef5/ausfahrten/includes/classes/safehtml/safehtml.php on line 367
Rolf ::: 11. Feb 2004 ::: 18621 Aufrufe
Rolf ::: 11. Feb 2004 ::: 2647 Aufrufe
Punktesystem Flensburg Zum 1.1.1999 wurde das Punktesystem neu geregelt. Wichtigste Änderung dabei: die Teilnahme an einem Aufbauseminar (ASP) wird ab einem bestimmten Punktestand zur Pflicht. Punkte bleiben für mindestens zwei Jahre in der Flensburger Kartei bestehen, bei Punkte, die aus Straftaten her rühren, verlängert sich die Frist auf 5 Jahre.
Seite << | 1 | 2 | 3 | >>
Deprecated: Function eregi() is deprecated in /www/htdocs/w0058ef5/ausfahrten/footer.php on line 30
Deprecated: Function ereg_replace() is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/books/pnblocks/randombook.php on line 53
Deprecated: Assigning the return value of new by reference is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/dpStaffStatus/pnblocks/dpStaff.php on line 40
Deprecated: Assigning the return value of new by reference is deprecated in /www/htdocs/w0058ef5/ausfahrten/modules/dpStaffStatus/pnblocks/dpStaff.php on line 113
Benutzer: |
Heute neu: |
0 |
Gestern neu: |
0 |
Total: |
383 |
Letzter: |
Noiajf |
Online |
Benutzer: |
0 |
0 |
Total: |
0 |
Mitglieder online |
Es sind keine Mitglieder online |
